D4 flashing 92
Old Dec 4, 2012 | 10:06 AM
bigblock67's Avatar
Default D4 flashing 92
D4 light is constantly flashing. Replaced R 41 that cleared a prior shift issue. Replaced R 42 next for 41 but no change.
Thanks
Don
Old Dec 4, 2012 | 12:09 PM
Is there a question?
Suggest posting codes by observing D4 light flashes w/ service check connector shorted. See DIY forum for guidance on Check Engine Light diagnostics (same procedure but d4 will flash codes).
Old Dec 4, 2012 | 09:02 PM
bigblock67's Avatar
Check engine light is not on. D4 is flashing. Only issue.
Thanks
Don
Old Dec 4, 2012 | 09:16 PM
The D4 light flashing means the transmission computer detected a problem. You should check for transmission codes as TexasHonda suggested. The common diy thread on top of the gen tech help forum has a link to checking engine codes.
Old Dec 4, 2012 | 09:32 PM
bigblock67's Avatar
Thank you. Will commence chasing issue
Don
larry91403
Aug 21, 2006 02:42 AM
DSMtraitorPhil
Aug 2, 2006 02:02 PM
jrcastro
Jun 25, 2006 12:03 PM
davidk
Sep 16, 2005 01:55 AM
moranger
May 11, 2005 10:23 PM
