im new!! in need of help!!
Old Dec 2, 2012 | 12:35 AM
94accord-lx's Avatar
Default im new!! in need of help!!
Hi i have a 94 accord lx and im having a problem with my brake light......
My passenger side brake light doesn't work i have changed the bulbs changed the wire harness and it still doesn't work.... all of my other lights work (all running light both reverselights both turn signals and thre thrid brake light and the driver side light) but the passenger side brake light i don't lose what else to do i need help bad pl thanks
94accord-lx
Old Dec 2, 2012 | 04:06 AM
If u need more info just ask plz i will post a video if my phone allows me to later on as well
Old Dec 2, 2012 | 10:24 AM
Is the "dash" telling you that a brake lamp is out?
Do you have a volt meter to check continuity of a ground wire and voltage of another......what is the number of the bulb you installed.
Old Dec 2, 2012 | 11:59 PM
Yez the dash light is sayin brake lamp or what ever...
I have replaced the bulb many times i have switched it withe the bulb left side but for some reason the right side still wont work
I have also change out the harness for it as well n it worked for it a few seconds and it now doesn't work again
N so we r cler this is only the right side brake light we r talkin about all the others work just fine
Old Dec 3, 2012 | 12:02 AM
I dont kno the exact bulb number but it is the right one and i dont have a volt meter
Old Dec 3, 2012 | 03:01 AM
94ex915's Avatar
Almost A Senior Member
So is the parking light working and not the brake light or the light is not working at all? I had a similar problem but all I did was hit the light gently with my hand it and started working again .
Old Dec 3, 2012 | 08:21 PM
I'm thinking something in/with the failure sensor on the drivers/left side is not right. Power for the pass rear bulb comes from this sensor that is on the drivers/left side of the car.
The GRN wire from the drivers/left rear failure sensor sends power to the righ/pass side light....so the dash tells you the brake light is out.....is it getting voltage?
Old Dec 3, 2012 | 11:03 PM
Im not to sure if its gettin voltage or not i currently don't have a volt meter
Old Dec 4, 2012 | 06:55 PM
With your test light, see if the green wire to the pass side has voltage when the brake pedal is pressed.
EDIT: For some reason I think it is a GRN/WHT wire even though the pic says GRN....but I'm getting old.
Old Dec 4, 2012 | 10:06 PM
Ok wen i get the chance i will and update as well
Justin Daniels
Jan 23, 2013 06:10 PM
Positronic
Jan 13, 2013 05:09 PM
Bcleader
Oct 24, 2012 05:37 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
