im new!! in need of help!!
Hi i have a 94 accord lx and im having a problem with my brake light......
My passenger side brake light doesn't work i have changed the bulbs changed the wire harness and it still doesn't work.... all of my other lights work (all running light both reverselights both turn signals and thre thrid brake light and the driver side light) but the passenger side brake light i don't lose what else to do i need help bad pl thanks
94accord-lx
94accord-lx
Yez the dash light is sayin brake lamp or what ever...
I have replaced the bulb many times i have switched it withe the bulb left side but for some reason the right side still wont work
I have also change out the harness for it as well n it worked for it a few seconds and it now doesn't work again
N so we r cler this is only the right side brake light we r talkin about all the others work just fine
I'm thinking something in/with the failure sensor on the drivers/left side is not right. Power for the pass rear bulb comes from this sensor that is on the drivers/left side of the car.
The GRN wire from the drivers/left rear failure sensor sends power to the righ/pass side light....so the dash tells you the brake light is out.....is it getting voltage?
With your test light, see if the green wire to the pass side has voltage when the brake pedal is pressed.
EDIT: For some reason I think it is a GRN/WHT wire even though the pic says GRN....but I'm getting old.
Levibyz
May 31, 2011 09:43 PM
