D4 light on, no start
You may need to find one at a junkyard for a discontinued part. See if you have any u-pull-it yards in your area. If not, you can call your local yards to see if they'd pull one for you.
If you enter the oem part number on hondapartsonline.net, that site lists other vehicles with the identical part number.
I think they both need to be in the same setting. If you plug in the connector to the range switch, look to see what gear the cluster indicates. If you can turn the range switch and the cluster changes the gear, then I'd probably put it neutral on the range switch and set the shift lever to neutral, then connect the cable.
