D4 light went off again in accord 1998
Old Aug 19, 2016 | 08:19 AM
Rilex's Avatar
Default D4 light went off again in accord 1998
Hello to you all in the forum, is being long i have been on this forum. My problem is with my D4 light which went off for sometime now. All other lights including the parking light is showing on the dashboard except for the D4 lights. The automatic transmission still shifts smoothly with no jerking. i did not notice any problem with the transmission because it still engages fast with no hesitation. Also the auto cruise is not functioning. could there be bad fuse responsible for all these malfunctions or there is blow out of D4 light? Please kindly respond because your opinion or suggestion will be of much help to me. THANKS. Auto transmission, 1998 honda accord. 2.3 Lx, 4cylinder, milleage 230,000
Old Aug 19, 2016 | 11:36 AM
You may have a bad D4 bulb in the cluster.
There can be various reasons the cruise control doesn't work. I'd recommend checking for codes on your vehicle.
I saw your other post about cleaning the EGR port. The 2.3 port is on the right hand side of the intake manifold (right side if you were sitting in the driver's seat). I believe the throttle body/upper intake can be removed together.
See this video:
Old Aug 19, 2016 | 03:06 PM
Rilex's Avatar
thanks for replying how do I replace the D4 light bulb. Are we to remove the dashboard to get to where the bulb is?
Rilex
Mar 14, 2016 02:45 PM
Rilex
Mar 19, 2014 05:13 PM
Rilex
Feb 24, 2014 05:33 PM
bigb609
Dec 27, 2011 07:18 PM
Jun 2, 2006 02:24 AM
