D4 Lite on my 92 Accord
Old Jan 2, 2007 | 06:27 PM
RedCruiser's Avatar
Default D4 Lite on my 92 Accord
I recently noticed that my D4 light goes out when I put the car in Drive.
If the car is in Parking, it works fine.
Any ideas?
Old Jan 2, 2007 | 07:35 PM
drummer1279's Avatar
Default RE: D4 Lite on my 92 Accord
is the car still shifting ok? you probably just have a light burned out if that be the case.
Old Jan 3, 2007 | 10:32 AM
RedCruiser's Avatar
The shifting is perfect.
Old Jan 8, 2007 | 09:26 PM
hondadude's Avatar
Contacts in the shift position switch under the console maybe?
Old Jan 8, 2007 | 09:32 PM
if that be the case and the car is shifting fine then the only hinderance you would have is if your check engine light came on and you needed to pull a code. bacause you read the flashes from the D4 light.
Old Jan 8, 2007 | 10:33 PM
MichaelEXL's Avatar
I just replaced the bulb in mine last month, it was not easy for me, as I couldn't remember what went where on the gear shift. The dealr gets $45.00 for the bulb on the gear shirt, if its in the fdash they told me its about $125.00 asyou have to pull the dash apart.
Old Jan 10, 2007 | 12:38 AM
92halx
i hv a 92 accord and my d4 light in dash went out too about a month ago. they must only last 15 years. ive learned to live with it. removing the dash is alot of work to replace a bulb
SPD-2000-HONDA-ACCORD
Mar 29, 2013 08:50 AM
biggamejojo
Apr 17, 2011 09:11 AM
getreal19783
Feb 2, 2007 03:01 PM
deserthonda
Jun 20, 2006 05:21 AM
deserthonda
May 18, 2006 05:24 AM
