Damaged Headlamp replacement question
Old Nov 18, 2016 | 06:09 PM
k4b4li's Avatar
Default Damaged Headlamp replacement question
Hey all, I'd really appreciate pointers to my situation here: I went and hit a truck parked in front of me when pulling out of a parking spot. Nothing happened to the truck, but my car has suffered some damage. I went to the body shop and they said the brackets need to be re-fit, and the right headlamp replaced. Thing is, the headlamp works, it's some internal plastic that's broken (the sheet between two lights?).
My question is - does it need to be replaced in its entirety? Is it not possible to replace/repair parts inside the headlamps individually? They quote $400 for the headlamp. Are there any cheaper alternatives?
EDIT: I just found that carid quotes $170 for the exact same thing: https://www.carid.com/tyc/passenger-...9357-00-9.html
EDIT: Today I learnt about aftermarket parts and that the above is an after market part. Maybe I could buy this and take it to the shop and have it installed. What would it do to the car's replacement value?
Am I missing something here or is the auto shop taking me for a ride?
Thanks.
K4B4LI
Honda Accord 2014 4D LX 2.4L CVT
Old Nov 18, 2016 | 06:38 PM
Without some pictures, I'm not sure what is broken on the headlights.
The headlights are sealed, so you can't replace parts inside the headlight. It looks like the plastic arms/brackets that hold the headlight to the car can be replaced.
A new headlight from honda runs about $300, so the price they quoted you may be fair. My TSX had aftermarket headlights installed sometime before I bought it. They don't seem to hold up like the Honda lights, so I'd recommend OEM honda lights for the extra money.
Old Nov 18, 2016 | 06:50 PM
k4b4li's Avatar
Amazon seems to suggest new parts for the exact same item number they quoted for 273, and used parts are available from 181. I wouldn't mind using used OEM parts if it's not damaged or anything, if it gets me a cheaper price.
I bought the car when I had a steadier income haha, hence my price haggling.
Old Nov 22, 2016 | 10:40 AM
dgp1961's Avatar
Almost A Senior Member
It's only two years old for $400 try to fix it correctly. Maybe you can save the money up somehow and get it done.
Wrecked94Accord
Jul 5, 2011 02:59 AM
mukman22
Mar 25, 2008 01:25 AM
mukman22
Mar 7, 2008 12:00 PM
mukman22
Mar 6, 2008 01:14 PM
oskizzle
Feb 19, 2007 01:22 PM
