dash brake light lights when brakes are pressed
Old Sep 29, 2006 | 02:36 PM
lea02coupe
Default dash brake light lights when brakes are pressed
i have a 2002 accord v6 coupe 124k miles
the brakes do not make any noise but just this morning when i depress the brakes the brake light on the dash lit up for a few seconds?? anyone had this problem? do you think there is a problem with my car/brakes?? any help is appreciated. I will have to take off work to take my car to the shop if needed, plus the expense of a repair.
Old Sep 29, 2006 | 03:22 PM
sir_nasty's Avatar
Default RE: dash brake light lights when brakes are pressed
Welcome to the forum! Sounds like it may just be low fluid, check your brake fluid level
Old Oct 1, 2006 | 12:31 AM
The warning lamp for the handbrake will also light up for low brake fluid. There's a float switch in the reservoir.
But there's a different warning lamp for 'brake lights'. That one's supposed to go off when a brakelight bulb is burned out. Sometimes it's too sensitive & it light up when one socket is corroded or dirty, even though the bulb still works.
SO.... which warning lamp is it?
hondaisreal
Oct 28, 2012 09:01 PM
victorywhity
Mar 24, 2011 09:37 PM
jbraly
Aug 12, 2009 02:02 PM
