in dash fue box question
Old Jan 31, 2007 | 02:11 AM
kennilope's Avatar
Default in dash fue box question
Hi. I m installing OEM fog light for the 94 Accord.
I came across 4 options pin on top of the fuse box which label 1 2 3 5
does anybody know what does those do?
I just wonder what does those terminal are for.
Thanks in advance.
Old Feb 1, 2007 | 03:37 PM
kennilope's Avatar
Default RE: in dash fue box question
I guess nobody know what I am talking about or you guys have no idea what it does.
Old Feb 2, 2007 | 12:16 AM
hondadude's Avatar
yesI know the connections you are talking about and you should find one of those that has power only with the key on; however you should still use an inline fuse for the lights.
Old Feb 2, 2007 | 03:55 PM
kennilope's Avatar
Do u know which pin is that??
so that is like a remote pin
it only turn on when ingintion key is on.. off when u take out key right??]\\
Old Feb 2, 2007 | 04:19 PM
sir_nasty's Avatar
just get a tester and you can figure out which one it is... it will only be on when the ignition is...
Old Feb 2, 2007 | 09:23 PM
kennilope's Avatar
yeah but i want to know if it is constant 12v or 5 volt or whatever....
anyway thanks i will try it out when i have time
Old Feb 2, 2007 | 09:31 PM
sir_nasty's Avatar
it should be a constant 12v with the ignition on, turns off with the car... which one? I don't know..
Old Feb 3, 2007 | 03:22 AM
deserthonda's Avatar
if you just need a power supply ,, do as Sir suggested, turn the key on, get a test lite, hook the clip side to a good ground and touch the pin in the fuse box,, the one that lites up , of course has power,, now keep the test lite where it is at, turn the key off , test lite should turn off as well , if it still stays on you do not want that connection cause it has power all the time and if you connect something to it , it will stay on and drain the battery ..
jerrym
Jan 31, 2014 07:57 AM
Esmith
Jul 9, 2008 11:52 AM
kumazam
May 28, 2008 12:22 PM
artanis7
Aug 17, 2007 01:42 PM
ivrex
Dec 10, 2006 03:24 PM
