DASH WENT DARK
Old May 22, 2007 | 09:57 PM
mig25's Avatar
Default DASH WENT DARK
[:@]I was replacing the radiator fan timer under the dashboard, I unplugged a big aluminum box with two plugs on it, it was on my way so I removed it.
then I took the radiator fan timer and replaced it.
When I crank the car my Gauge cluster lights do not come on anymore, Have checked fuses under the dash and the engine compartment and found none burned out.
Any clues what could be happening here ?
All lights we normal prior to removing this box and plugging it back , Any tip will be appreciated.
Thank you.
Old May 22, 2007 | 10:20 PM
evilash05's Avatar
Default RE: DASH WENT DARK
did you try to unplug the battery ,let it sit for 10 mins or so, then plug it back in...may just need rebooted.
Old May 23, 2007 | 06:42 AM
mig25's Avatar
I will try that later on... I have removed the ECU fuse to reset it though, but did not help...
Again, I only checked the Fuse on the left side kick panel and the one under the hood where the relays are behind the ABS reservoir.
Should I check any other fuses?
Also when my engine is hot , I turn the ignition Key off the fan now runs exactly 15minutes, I believe that is normal, I am correct ?
But I left it idle after I drove it on the HWY and the fan never came on, the temp gauge stayed normal, never went pass the half mark...
I find that kind of odd
PapillonOne
Dec 21, 2013 10:30 AM
ProZak512
Dec 23, 2012 09:08 AM
Ericsmiller88
Feb 19, 2008 04:56 PM
hellomoto
May 4, 2006 01:12 AM
oldaccord
Oct 13, 2005 02:56 AM
