Dealer wants to replace Starter Immobilizer Assembly
Old Feb 10, 2020 | 09:33 AM
Hepoom's Avatar
Default Dealer wants to replace Starter Immobilizer Assembly
Hi, struggling to find examples of this online where this was the solution.
My problem: the alarm on my 2014 Accord goes off some nights when I’m in my house or even down the block. Usually happens at 3-4 am, greatly annoying the neighbors. It happens several times in a row, then stops.
Sometimes the amber security system dash light comes on, but never any other warning lights. When this problem comes up, the key fob usually doesn’t work. I’ve never had a problem starting the ignition.
I thought the issue was maybe the hood latch sensor going off due to temperature or moisture changes early in the morning. But the service advisor tells me it’s definitely not that.
Dealer wants to replace the Starter Immobilizer Assembly, $485 for parts, plus $462 for labor.
Anyone heard of such a problem? Does this solution make sense to you guys? It’s a lot of money and I just want to make sure it will actually solve my problem.
Thanks for any help. 😃
Old Feb 10, 2020 | 10:10 AM
Seanjordan20's Avatar
I've heard of replacing it since the car didn't start but not of your issue
Old Feb 10, 2020 | 10:11 AM
Have you tried resetting it
Old Feb 10, 2020 | 10:19 AM
Have you had the battery sensor done on your car yet. You may want to call Honda to check.
jd60fe
Mar 18, 2015 05:04 PM
Rob2000AccordLX
Dec 14, 2014 05:34 PM
trolddk
Jun 15, 2009 08:03 AM
finch13
May 24, 2008 04:15 AM
clarity
Dec 26, 2007 06:19 AM
