Deleting ABS
Old Aug 8, 2023 | 07:18 PM
JR2's Avatar
JR2
Default Deleting ABS
Hello to all and thank you for reading my post. My 95 EX was in a accident and the ABS UNIT was destroyed. I fixed everything but the unit. I can't find a NEW or USED unit at this point. So, I went to a salvage yard and removed a proportion valve from a non ABS car to install in mine so I can delete my unit. The problem is, nothing will line up of course, and if this can be done, where do the lines go?? If I must, I will go back to the salvage yard for the lines and or direction of the lines. Thank you
Old Aug 8, 2023 | 10:29 PM
Is your 95 EX a 4-cylinder or 6-cylinder?
It looks like the 94-97 accords used the same abs module along with the acura integra.
You can check out a site like car-part.com that searches junkyards for parts, where you can sort by price or distance. You may be able to find a replacement on that site where you can reconnect your original brake lines.
Old Aug 9, 2023 | 08:09 PM
JR2's Avatar
JR2
Thank you for the response... I have a 4cyl. 2.2l with MT. I have checked local yards with no availability. I also checked the web and seems all are out of stock or deleted... I know your stand on this subject, but I am looking to delete the unit and go NON ABS.... So I thank you once again.... Have a great day
Old Aug 9, 2023 | 10:16 PM
My thought was installing a non-functional ABS would be easier than swapping over all of the non-abs accord lines as long as the abs unit was not leaking. You wouldn't have a functioning abs, but the install would be simpler.
You best bet is to look up the OEM part numbers for the lines on a non-abs accord vs an abs accord on a site like hondapartsnow.com. Then you can see what items you need to pull from the non-abs accord at the junkyard. Hopefully, you won't have to pull the lines that run under the plastic shield going to the rear wheels for the lines.
Tesla
Mar 19, 2012 06:00 AM
Antarctica
Oct 30, 2008 08:16 AM
louofm1
Mar 10, 2008 09:44 AM
pturnbul
May 3, 2007 02:30 PM
Yangster
Aug 31, 2006 02:17 AM
