Desperate for help with 91' honda accord
Old Jun 15, 2009 | 04:37 PM
honda86's Avatar
Default Desperate for help with 91' honda accord
I need help i had to replace my vacum hoses but not sure which one goes where ? thank you for the help
Old Jun 15, 2009 | 05:24 PM
finch13's Avatar
A picture or description would help. There are so many vacuum hoses on the engine I don't know how to help you. And if you just had to replace one, that shouldn't be too hard to find.
Old Jun 15, 2009 | 09:08 PM
There should be a vacuum routing diagram under the hood of the car.
If it's missing, try going to autozone.com and looking up vacuum diagram for 90 Accord.
You could also download one of the 90-93 Accord manuals from the Online Manuals DIY links.
Old Jun 16, 2009 | 10:22 AM
honda86's Avatar
hey thanks i tried those and got nothing but i can explain where the hoses are there are 4 of them coming of the fuel injectors (if your looking at the motor on left side). thanks and maybe that will help determine which way they go ,again thanks alot
Old Jun 16, 2009 | 07:31 PM
You didn't look very hard at autozone.com. Here is vacuum diagram. There are also pictures and note that vacuum tubes are numbered to help ID.
http://www.autozone.com/autozone/rep...00c1528005f53e
Old Jun 18, 2009 | 04:01 PM
honda86's Avatar
Exclamation More Problems
Now I am having problems with some other stuff like, driving down the road the car drops out of gear (can't go anywhere) ,second thing car suddenly dies (speedo quits first if that helps) now the big problem my brakes. Sometimes I will will have stiff brakes next time i have almost none ,and while my car is in park and i press the brakes they go down and stop but for a few seconds then they release and go all the way to floor , last thing the sports light is always flashing no clue why Well please help me as soon as possible thank you so much for the help
Old Jun 18, 2009 | 04:50 PM
Your signature says that you have a 90 accord, but you said that is a 91. Fix signature if that is the case.
The brake issue is likely a leaking master cylinder internally externally. Check the brake fluid level. If it is ok, then I would replace or rebuild the master cylinder. There is a DIY writeup about it.
Your D4 light flashing means that the transmission computer is detecting a problem and set a code. Get that code and post it on here. If your car is a 91, follow the instructions in the link below. Use a thin paperclip or thin wire to short the connector. Count the D4 light flashes to get the tranny code. Also count the check engine light flashes (if any).
http://www.dhost.info/accordinfo/howto/cel.html
Old Jun 18, 2009 | 06:50 PM
deserthonda's Avatar
Pa ,,, if the car is a 90 or 91 he will never find the connector following the link below... 90-93 the connector is located on rt side under dash by the kick panel , sometimes behind the kick panel , it is a blue connector might be wrapped up with blue tape ..
eight_05_south
Aug 17, 2012 10:15 AM
drummer1279
Aug 17, 2007 09:57 AM
darkside099
Jun 10, 2007 12:01 AM
suprarx7nut
Apr 11, 2007 02:19 AM
hawaiian5
Dec 6, 2006 03:41 AM
