Desperate For Help with RF Caliper
Old Oct 19, 2014 | 05:55 PM
Grand Rapids's Avatar
Default Desperate For Help with RF Caliper
It was been awhile since I posted, been busy with moving to a new house.
For the last three weeks, my '03 Accord has had a sticking RF caliper, even after replacing both fronts.
It first started out as both front calipers sticking AFTER replacing the factory originals (at 114,000 miles).
At the same time, I replaced the front rotors and pads again, thinking they may be worn unevenly due to the sticking caliper(s).
Today, I did a warranty exchange and replaced the front calipers again. The driver's side is fixed, but the passenger side continues to stick -- no change at all.
When moving, all I hear is the loud squeaking from the passenger side.
When I brake, naturally, it mostly goes away.
Here are the links for the calipers I used from Advance Auto Parts:
Fenco Unloaded Caliper with Bracket SLC9856: Get the best Brake Caliper - Front at Advance Auto Parts
Fenco Unloaded Caliper with Bracket SLC9857: Purchase the best Brake Caliper - Front at Advance Auto Parts
Any help is greatly appreciated and I thank you in advance. This is truly frustrating.
Old Oct 19, 2014 | 06:44 PM
woody31's Avatar
Almost A Senior Member
Make sure the shims are in place and everything is lubed correctly, aside from that , if you are still having issues,, replace the front brake hoses,,do both sides at the same time,,sounds like your hose has collapsed from the inside, good luck and keep us posted.
Old Oct 19, 2014 | 07:09 PM
I will take it all apart again tomorrow to lube. However, I don't know if it would be the brake hose because it was determined the LF caliper was bad to start with; the RF old caliper didn't make any noise until it was replaced.
Thoughts?
Old Oct 20, 2014 | 06:10 PM
I'm easy to confuse so forgive me.
A sticking claiper will not make a "noise".
To check the slide pins, remove the lower bolt from the caliper braket. Tilt the caliper up, might have to remove the bolts that hold the hose to the knuckle, and pop the pads out. Tilt the caliper down and install the lower bolt.
Does the caliper slide in and out on the pins without sticking?
Old Oct 20, 2014 | 06:19 PM
Turtlehead's Avatar
If the car stops smooth and straight then it is the lack of the anti squeal compound on the shims not the calipers or the pads. That is assuming that you have just replaced the caliper including the caliper frame.
Old Oct 22, 2014 | 08:35 PM
All of you were correct in your assessments. However, in my case, it turns out I didn't push the pads down all the way into the caliper. So, it was rubbing.
It is correct (and should have been logical to me) that a sticking caliper will not make noise.
Turtle: While I was at it, I went ahead and used anti-squeal compound. Wasn't making noise, but I did it anyways.
Thank you all for your help.
Next issue: The backlight on my radio/climate control is out. Common problem? Is there a thread on here that gives a step-by-step on how to fix this?
Old Oct 22, 2014 | 10:09 PM
I think there is a resistor on the circuit board that you have to replace. I remember seeing a youtube video on the repair.
Old Oct 23, 2014 | 01:49 AM
I really can't find anything thorough. Can anyone give me any tips on this? What would I search on YouTube?
Old Oct 25, 2014 | 08:09 AM
Using google I typed in "2003 Accord radio light" and got serveral video's, ect on the subject.....I didn't go any further by watching or reading them.
HondaAngel
Apr 28, 2008 07:49 PM
drummer1279
Aug 17, 2007 09:57 AM
darkside099
Jun 10, 2007 12:01 AM
suprarx7nut
Apr 11, 2007 02:19 AM
hawaiian5
Dec 6, 2006 03:41 AM
