desperate need of help with 97 v6 automatic accord
Old Aug 15, 2012 | 02:59 PM
eight_05_south's Avatar
Default desperate need of help with 97 v6 automatic accord
. Here's my issue. My wifes accord had a bad rear main seal leak, took the tranny off replaced the seal and bolted the tranny back on,went to put the bolts that connect the flexplate to the torque converter. Now the crank is stuck.any1 have any ideas on how to solve this issue. Also I must have removed the shift linkage while it was in gear bcuz now I don't here the tranny shifting gears. I haven't started the car yet still have to put some parts back togeter.please help
Old Aug 15, 2012 | 06:38 PM
How are you trying to turn the crank?
Old Aug 16, 2012 | 09:25 AM
Using a socket wrench. I solved that problem. Had to realign the flexplate and torque converter. Now my prob is a check engine light and blinking d4 light
Old Aug 16, 2012 | 10:50 AM
doctorbee's Avatar
pull the CEL and d4 codes
Old Aug 17, 2012 | 10:15 AM
Problem solved the torque converter and flexplate were'nt aligned. Cars up and running again
honda86
Jun 18, 2009 06:50 PM
HondaAngel
Apr 28, 2008 07:49 PM
drummer1279
Aug 17, 2007 09:57 AM
hawaiian5
Dec 6, 2006 03:41 AM
calenatar
Mar 8, 2006 06:38 PM
