Desperatley SEEKING HELP 91 Accord ECU Problem!!!
Old Dec 6, 2007 | 07:00 PM
nafango2's Avatar
Default RE: Desperatley SEEKING HELP 91 Accord ECU Problem!!!
the fuel pump is very quiet. It should be coming from underneath the passeneger side of the rear seats. it will turn on for only about 2 seconds when you turn the key to ON.
Old Dec 6, 2007 | 07:02 PM
hurraquio
I know, but after the fuel pump cycles (when it was working) the relay clicks and the engine lght shuts off then the car would start.
Old Dec 7, 2007 | 12:45 AM
deserthonda's Avatar
sounds like a blown ECU fuse ... you said all the fuses are ok ?? did you chk the ECU fuse in the underhood fuse box ?? for sure it is good ??
Old Dec 7, 2007 | 01:51 PM
hurraquio
yes the all the fuses on the underhood side are good, yesterday i disconnected the battery to see if the ECU could reset, when i get home today, im going to check the firewall then make my way to the ECU do any of you have the trouble codes?
Old Dec 7, 2007 | 02:04 PM
sir_nasty's Avatar
did you try to short the service connector and check for codes?
Old Dec 7, 2007 | 02:09 PM
hurraquio
not yet i will do that when i get home only two more hours to go i cant wait to try it outhopefullly it can get going.
hotrodder1973
Oct 2, 2011 08:29 PM
imabadczech
Aug 2, 2010 11:18 AM
moosehead
West
Jun 21, 2010 02:56 PM
driscollmv
Jan 14, 2010 12:57 PM
Bluezriff
Jun 1, 2007 09:21 AM
