Dexron III?
Old Jun 11, 2006 | 05:19 PM
95exr
Default Dexron III?
Hi Folks,
I recently went to Mr.Lube and had my oil changed with Mobil 1 synthetic they also drained my tranny fluid and put in Dexron III .....is this stuff ok or should I be concerned?
Also my ABS light just came on this week and remains on after about 30 seconds of driving.
Any input would be greatly appreciated.
Thanks,
Sean
Old Jun 11, 2006 | 06:00 PM
YeuEmMaiMai's Avatar
Default RE: Dexron III?
Honda ATF only. Honda states you can use it in a pinchbut it should be replaced with Honda fluid at soon as possible
Old Jun 11, 2006 | 06:40 PM
lightshow's Avatar
honda fluid only. get that other stuff out of there immediately. i mean dont even drive it to the shop, get it towed.
Old Jun 11, 2006 | 09:32 PM
deserthonda's Avatar
ORIGINAL: 95exr
Hi Folks,
Thanks,
Sean
since it is on the sig , the year and model i have to assume going by your name that the car is a 95 accord...........
Although i agree with Yeu and Light ,, that it is better for the tranny to have honda flud ATF-Z1 it is also ok to have Dextrom III ,, no need to panic, it IS NOT going to do any damage,, However i would go with honda ATF-Z1 on the next fluid change ..
And lightshow my friend ( have the car towed ) ?? .... Honda says the using a non honda fluid CAN AFFECT shifting quality ) but even they say that using DEXRON III is OK..
Old Jun 11, 2006 | 10:31 PM
95exr
Ok Guys thanks for the info.
deserthonda yes you are correct my username is current. I will switch to the Honda stuff next time I change the fluid.....hopefully the Dexron III will be ok. Any ideas on the ABS light?
Old Jun 11, 2006 | 10:37 PM
you will need to jump the sc ( service connector ) located under the glove box, blue plug, 2 wires going to it,, than put the ignit key on and count the # of flashes on the dash instrument cluster,,
it might have 1 blink,, slight pause 2 blinks ,, that's code 1-2
if 1 blink, longer pause 1 blink it is just code 1 ..
but before i can tell you what is going on i need to know the abs code ..
Please input year and model on your sig so everyone who tries to help does not have to ask you .....
Old Jun 11, 2006 | 10:56 PM
95exr
Thanks deserthonda.......I will post back here once I complete that task.
Much appreciated......and my sig has been updated as well.
brokanic
Dec 6, 2010 01:22 AM
johnb06accord
Feb 5, 2008 12:00 AM
razcob
Jan 7, 2008 08:02 PM
984DRAccrd
May 8, 2007 02:50 PM
rcy
Apr 14, 2007 09:50 PM
