Will the evo iii fit?
Old May 8, 2007 | 04:22 AM
984DRAccrd
Default Will the evo iii fit?
Hey
Does anyone know if the evo iii turbo off theEclipsecould be adpated to fit under the hood of a 98 Accord f23a (4cyl v-tech)? Of course with proper manifolds and all? Its bolt on so I'm hoping there won't have to be no major "customization" to make it fit because I have plans of a whole new set-up in the way future!
All positive feedback would be appreciated!
Old May 8, 2007 | 11:08 AM
marbro's Avatar
Default RE: Will the evo iii fit?
Yes you can use it,I would just be sure that you can get the turbo as it self nothing welded on the manifold side or the exaust side and you can do anything with it. About the only adjustments that would be made would be matching the manifold (possible adapter plate) matching the downpipe, and the position of the compressor side for the charge piping.
The manifold and downpipe you would find out most of based on the turbo model
oh, and if its an internal wastegate, found out what psi its set at.... I know you can adjust those but im not sure exactly how, but either way it could effect if you get it or not
Old May 8, 2007 | 02:50 PM
95bentleyLX's Avatar
different companies make manifolds to accept the dsm turbos, many even sell mani/d.pipe kits, eliminating any need for a "custom" setup. i see them everywhere on ebay for civics, which means someone out there has one for the accord. as for thewastegates, they're all internal on dsm's im pretty sure 1st gen. is about 12psi, and 2nd gen a bit less, maybe 8-9psi, which is why most people go w/ the 14b............
diysetups w/ dsm turbos are VERY common
Tex_hooper
Sep 23, 2013 06:43 PM
vdaaccord06
South West
Apr 29, 2009 10:37 AM
johnb06accord
Feb 5, 2008 12:00 AM
amybee
17
Oct 24, 2007 12:25 AM
95exr
Jun 11, 2006 10:56 PM
