Did throttle body cleaning now car wont start HELP!
Hi guys,
I have a 1999 EX 2.3 CYL that had the infamous P0401 code so after reading many threads I decided to try the throttle body and egr cleaning. I had to take off the upper plenum which has a bunch of hoses and a couple of sensors attached in order to pull the the intake out and give it a good cleaning. After doing that and putting everything back together now the car doesn't start. It cranks but doesn't turn over. I will state that while separating the throttle body from the intake the cruise control cable came out and we put it back fine I assume from the pictures that I took prior to taking on the job. Any ideas what I could have done wrong. Please help need to go to work on Monday!
Hondadude your suggestion to go back and recheck my work along with Poorman212 suggestion to check the main ground did the trick.
I noticed that I had left the main ground unattached. The car is running great and I noticed there is no longer a hesitation when accelerating from a dead stop. Thanks for everyone's input. This forum is absolutely indispensable.
dtcaccord
Jun 4, 2008 09:54 PM
jose310
Feb 3, 2008 04:31 PM
