Dies at half a tank?
Old Jun 16, 2007 | 12:27 PM
mla91EX
Default RE: Dies at half a tank?
I will check for the codes this weekened. As far as the fuel filter goes, that was changed 3wks ago.
I've been told that there could be a hole in the return line. Is there a way to check for that...or would the pressure test do that for me?
Old Jun 16, 2007 | 01:08 PM
A hole in the return line would make a puddle of gasoline under the car. You would have noticed that??? And it would let the engine run just fine until it ran out of gas.
A hole in the suction nozzle of the pump, inside the gas tank sounds more like it. With a full tank, it would suck gasoline in thru the hole, & work OK. When the gas level dropped below the hole, it would suck air.
Old Jun 16, 2007 | 03:00 PM
mla91EX
Ok, and to fix that would I have to drop the tank? Or can it even be fixed without buying another tank?
Old Jun 16, 2007 | 03:40 PM
sir_nasty's Avatar
If it's a problem with the tank's pickup line then you would have to drop the tank to remove the fuel pump. It's held up into place by essentially 4 bolts. There is a drain plug underneath, however, I'd defenitly do some more testing before I went that far....
Old Jun 16, 2007 | 04:34 PM
mla91EX
I am, trust me I am. I'm not gonna do all that and it turns out its just the damn gas cap..lol
Thanks for all the help and suggestions.
Old Jun 17, 2007 | 11:46 AM
Yeah, definitely test (& rule out) all the easy stuff before dropping the tank.
jessecolter
Sep 22, 2014 12:11 PM
jessecolter
Sep 2, 2012 08:58 PM
Nicolai Hobbs
Jul 12, 2012 05:44 PM
klhiggi
Sep 3, 2009 01:45 PM
amyandrew2
Apr 15, 2006 03:40 PM
