Dies at stops
Old Jul 1, 2013 | 02:36 PM
Miyavp's Avatar
Exclamation Dies at stops
Its an 1988 honda accord L4 2.0L Manual, Carborated. Whenever I'm at a stop sign or a light she dies if I dont keep reving the engine. I've noticed it happens when the RPM's are low. It kinda feels like she just kinda sputters and dies. It does the same thing when I park.in the driveway, it'll run really hard. Shaking and vibrating the car, but it I rev the gas it stops and then when the RPM's go back down it does it again. I recently had my exaust pipe break and my muffler totally fell off but that would'nt cause this would it?
I'd really aprciate any help I dont feel comfortable driving this car right now. Its my first car too
Old Jul 1, 2013 | 11:46 PM
I have never tried to troubleshoot a carb on a vehicle, so I can only give some basic advice.
I would suggest carefully inspecting each vacuum hose to ensure there are no leaks.
The common diy thread on top of the gen tech help forum has a link to the online manuals thread that has a hondatech link to an 86 shop manual. It should have some troubleshooting advice.
Old Jul 3, 2013 | 05:18 PM
Check what PA suggested but I only want to add a small bit. Sounds like you might have just got the car - do you know if the tune up items (plugs, cap, rotor) are up to date?
Old Jul 11, 2013 | 10:23 PM
Miyavp's Avatar
Sorry I haven't gotten back to you guys. We've had the car for quite a few years but I just got it myself. Graduation Gift. We just got the new muffler and exaust pipe put on and she's running a lot smoother but when I drove to my friends house today she died going down a small hill because I wasn't giving her any gas.
My friend had a similar problem on her chevy stepside truck and her grandpa her restores older vehicles is gonna look at the carborator for me because I have no idea what I'm doing. Hopefully that helps
Old Jul 11, 2013 | 10:24 PM
Miyavp's Avatar
I have no idea. I know I just got new brakes tires an oil change and a whole new exaust pipe and muffler. How often do they need replacing? We've had the car about seven years.
Old Jul 11, 2013 | 10:51 PM
There should be a sticker under the hood in the door jamb with the proper spark plugs. Get the NGK plugs that are recommended for your car.
I believe it is every 24K miles or two years. I usually go by mileage. Take a look in the owner's manual for that information.
Old Jul 28, 2013 | 04:09 AM
aussiechic2oo6's Avatar
Hey there! I've had the same problem with a previous car... it turned out to be the fuel pump! If you haven't checked for vacuum leaks, do so. Clean the IAC valve, clean the EGR valve. I suspect it might be the FUEL PUMP, but before checking and replacing it if it is faulty, how long has it been since you replaced the FUEL FILTER? I would do that before replacing the FUEL PUMP. Hope this is of any help!
Nicolai Hobbs
Jul 12, 2012 05:44 PM
mgharter
Mar 7, 2011 07:13 PM
xmx250
Oct 25, 2005 10:10 PM
krafte12
Sep 9, 2005 09:36 PM
mbliss
Dec 18, 2004 01:33 PM
