different issues
Old Sep 13, 2008 | 02:10 PM
  #21
drummer1279's Avatar
Default RE: different issues
you are referring to the BWD failing frequently right?
Old Sep 13, 2008 | 06:43 PM
  #22
No, the Mitsuba relay has caused fuel system failures in Accords andAcuras since at least 1990. I don't know why they are such a continuing problem. That relay should last the life of the car if designed correctly. I think the fault is too high current in the field winding of the coil. The entire relay is almost hot to the touch. This can't be good for longevity.
Of the faults that get posted on this forum, I would rank MFR very near if not at the top.
regards
Old Sep 13, 2008 | 10:04 PM
  #23
Ah I see. the BWD part apparently lasts a considerablely shorter amt of time. like I said the only issue I had with the mitsuba unit was the non starting on hot days. this newer part i guess decided to short out. Im going to buy a new Mitsuba unit and see what that does. thanks again for all the help.
Old Sep 15, 2008 | 11:13 AM
  #24
just an update, everything is still running fine. so hopefully that BWD main realy was the problem.
WIAccord
Nov 5, 2012 08:38 PM
kriegz99
Aug 11, 2007 08:41 AM
dj.fli4rt
May 30, 2006 01:37 PM
19accord92
Apr 10, 2006 03:52 PM
Kevin1250
Jan 29, 2006 02:17 PM
