Dimensions for screws
Old Jul 29, 2013 | 01:06 PM
tigershahkhan07's Avatar
Default Dimensions for screws
Hey, I recently bought an 95 honda accord coupe 2.2 4 cylinder vtec, turns out the cars doesnt have some critical screws, I was wondering if someone would be kind enough to send me the specs
- 1 ground strap cap screw (near the timing belt end of the valve cover)
- 3 distributor cap screws (currently held by vice grips)
Old Jul 29, 2013 | 01:16 PM
1st off Welcome to the HAF...
Reasearch time for your answer.. soon as someone see's it that knows.
Old Jul 29, 2013 | 02:19 PM
Ground screw is likely a 10mm socket size, 6mm bolt. Try swapping from another ground and purchase a replacement at auto parts.
Distributor cap screws will likely require a new distributor cap or Honda parts.
Old Jul 29, 2013 | 02:29 PM
I'm with Texas, try a bolt from another spot on the engine that is a 10mm. Then bring it to an autozone/advanced auto type store and try it in their bolt identifier display.
I'm guessing its M6x1.0 though.
Old Jul 29, 2013 | 02:59 PM
Ground bolt looks to be M6 x 1.0 x 16mm.
Metric thread diameter x thread pitch x thread length
As, TexasHonda stated, wrench/socket hex size would be 10mm.
Old Jul 30, 2013 | 04:39 AM
Thanks, fellas (& girls maybe) but as soon as I posted it, I pretty much guessed and checked had to go to an hardware store around here and the ground strap was a 10mm and the distributor cap screws were m .7, but I improvised, glad to see so many responses. thanks again!
Tenoke
Mar 7, 2014 05:19 AM
CRuby
Sep 24, 2012 05:22 PM
Thinkmoto
Feb 23, 2010 07:11 AM
liam71234
Oct 9, 2007 05:46 PM
Carina
Aug 14, 2006 06:31 PM
