Disconnected Hose and Electrical Connector near Transmission
Old Jul 29, 2017 | 01:13 PM
luchonda's Avatar
Default Disconnected Hose and Electrical Connector near Transmission
Hello,
I had a transmission fluid leak from the pressure switch that I fixed on a 2003 Accord. But now that I'm in here I see a disconnected line and electrical connector. The line comes across the top side of the transmission and just above the pressure switch. The electrical connector emerges from a wiring harness in front of the transmission. Anyone know where these should connect to?
Thanks,
Troy
Attached Thumbnails Disconnected Hose and Electrical Connector near Transmission-hose-above-pressure-switch.jpg   Disconnected Hose and Electrical Connector near Transmission-hose-2.jpg   Disconnected Hose and Electrical Connector near Transmission-electrical-connector.jpg
Old Jul 30, 2017 | 06:36 AM
Is this the four or six cyl?
Any chance you can get the wire colors of the "missing" connector - usually the wire will have stripe - so a green wire with a white stripe, we would call a "GRN/WHT" wire.
Also can you find the "other end" of the hose - does it go to an engine/trans mount or to a valve?
basket_case
May 10, 2015 06:06 PM
RA1525
Dec 16, 2013 07:42 PM
hack
Jul 12, 2011 06:12 PM
MsHonda901
Oct 31, 2010 03:54 PM
Ranmaster
Apr 12, 2008 08:24 AM
