Distributor 'ears' question
Old Apr 14, 2017 | 10:36 PM
okwriting's Avatar
Exclamation Distributor 'ears' question
On a 93 Honda Accord LX, the ears on the distributor broke off and are inside the engine. A new distributor was purchased and put in and it ran and drove good when tested, but the ears from the other one are still in the engine. Can they screw up something inside the engine if it's driven or will they just cycle through and land/stay in the oil pan?
Thanks in advance!
Old Apr 14, 2017 | 11:59 PM
The Toecutter's Avatar
Thanks in advance!
Where is the distributor located on a 93 engine? Just asking as I own newer Accords and am not familiar with the older models. If it attaches to the end of the head like the later ones do, then the pieces might still be up in the head. You could try taking the valve cover off and see if you can get them out.
Old Apr 15, 2017 | 12:09 AM
okwriting's Avatar
Yes, I believe it is. Is the valve cover and gasket fairly simple to remove and replace? Thanks!
Old Apr 15, 2017 | 12:13 AM
Which ears broke off? The ears on the key that connects to the camshaft, or the ears where the distributor cap bolts to the distributor?
Old Apr 15, 2017 | 12:16 AM
okwriting's Avatar
The bottom ones that stick inside the engine.
Old Apr 15, 2017 | 10:06 PM
Yes, I believe it's 5 nuts to remove (10mm wrench size). Make sure you use a piece of tape on each plug wire from right to left, numbering the tape 1,2,3,4. This way each plug wire goes back where it was, so the car will run.
Old Apr 15, 2017 | 10:29 PM
okwriting's Avatar
Yeah he did it earlier today, but the area where the distributor goes in is separated by a wall of metal so even tho he looked inside the valve cover, he couldn't see directly beneath to where the ears might have dropped. He searched as good as he could and didn't see them so we're hoping that when I was testing the power steering and brakes, (weaving back and forth and then going forward and back fast and hitting the brakes)maybe it fell and ended up in the oil pan.
Old Apr 16, 2017 | 08:26 AM
If memory serves me right, there is a "groove" of sorts to the inside where the dist goes into the head. If the dist is out, take a pick - bend a paperclip into a "L" shape - and run it in that "groove" just to be sure the old ears didn't get lodged in there.
I'm just trying to figure out how - why - they broke in the first place , that worries me more than anything else.
Old Apr 16, 2017 | 01:49 PM
okwriting's Avatar
We think it may have been because he inserted it wrong the first time - it may have weakened them. If that isn't it then I dunno.
John-Angela Hileman
Jan 13, 2017 09:04 PM
fusion1620
May 7, 2011 05:23 PM
ac398
Feb 12, 2010 05:35 PM
krussov
Sep 2, 2009 03:42 PM
Pacmanpth
Sep 9, 2007 11:43 PM
