Distributor o ring
Old Jul 14, 2011 | 08:32 AM
capthoward's Avatar
Default Distributor o ring
2001, accord, 4cyl -- is there an O ring or gasket that goes between the distributor and the engine or is the O ring everyone speaks of the one on the shaft that goes inside the engine??
Old Jul 14, 2011 | 11:49 AM
It is not on the shaft that spins inside the engine. It is on the distributor housing where the housing sits inside the hole for the cylinder head.
Look up distributors on Ebay for your car. They usually have pics for their parts and you can't miss the o-ring.
Old Jul 14, 2011 | 12:07 PM
capthoward's Avatar
Thanks, you explained it the way I wanted to ask it. Will replacing that O-ring stop the oil leakage there?
Old Jul 14, 2011 | 01:09 PM
It will fix a leak between the distributor and the cylinder head. It is a common problem.
If you remove the distributor cap and there is oil inside of the distributor, then there is another problem that the o-ring will not correct.
Old Jul 14, 2011 | 07:11 PM
capthoward's Avatar
Alright, thanks.
Shag Wagon
Oct 23, 2010 10:12 PM
wallawonder
Jun 15, 2010 12:13 AM
riverman
Apr 6, 2010 01:58 PM
tfunk
Feb 25, 2007 12:16 AM
Dhorn33
Jan 30, 2007 12:10 PM
