distributor wiring
Old Apr 27, 2008 | 10:29 AM
Default distributor wiring
i am putting a h22a4 into my accord. i am using the accord wiring harness. can anyone tell me how to wire up the stock prelude external coil or the jdm h22 internal coil distributor
Old Apr 28, 2008 | 10:36 AM
sir_nasty's Avatar
Default RE: distributor wiring
I don't know that off the top of my head but you could download a prelude manual then cross referance the wiring diagram to your 97..
Old Apr 28, 2008 | 01:39 PM
I dont even know what to do at this point, i have posted up on 4 different forums and no one has given me a solid answer.
The problem is the prelude distributor has 8 wires coming out of it the wire harness has 5 going to the distributor.
any one with a h22 swap want to tell me their distirbutor set up.
the onlything i can think of at this point is to use the h22 wiring harness, but then you get to sort through hundreds of wires on both the car and engine and solder them together because the harness wont plug into the car.
Old Apr 28, 2008 | 02:38 PM
sir_nasty's Avatar
Does this help?
Distributor Wiring I've had quite a few requests for distributor wiring so I've taken the time to add this update. The only wiring I have is for the H22a equipped with an internal ignition coil. [align=left] Sensor OBDI wiring (prelude dist) OBDII wiring (accord dist) TDC Orange/Blue Green White/Blue Red CKP Blue/Green Blue Blue/Yellow White CYP Orange Yellow White Black [/align] This is exactly how I wiring the distributor and it worked flawlessly. You may want to twist the wires and wrap them in tin foil to reproduce the shielded wiring that makes up the wires to the distributor.
http://importnut.net/h22a_swap.htm
Old Apr 28, 2008 | 09:03 PM
ORIGINAL: sir_nasty
Does this help?
Distributor Wiring I've had quite a few requests for distributor wiring so I've taken the time to add this update. The only wiring I have is for the H22a equipped with an internal ignition coil. [align=left]Sensor OBDI wiring (prelude dist) OBDII wiring (accord dist) TDC Orange/Blue Green White/Blue Red CKP Blue/Green Blue Blue/Yellow White CYP Orange Yellow White Black [/align]This is exactly how I wiring the distributor and it worked flawlessly. You may want to twist the wires and wrap them in tin foil to reproduce the shielded wiring that makes up the wires to the distributor.
yeah i've seen that but he lists 6 wires for the stock accord..........there are 5, and only a few of the colors are the same.
i'm in the process of completely taking apart both distributors to see what wires go where so that should answer my question
Old Apr 28, 2008 | 11:14 PM
The timing sensors in the distributor have changed a couple times over the years. What year H22 in your '97 Accord?
I won't really know the answer, but you can check wiring drawings for that-year Prelude against the distributor wiring drawing for '97 Accord.
Old Apr 28, 2008 | 11:42 PM
finch13's Avatar
My 95 had about 8 or more wires coming out of it going to two different plugs. I know that doesn't help, just saying...
Old Apr 29, 2008 | 05:39 AM
ORIGINAL: JimBlake
its a 98 h22a4
Old Apr 29, 2008 | 09:24 AM
Like I said I don't really know H22s all that well. But I think beginning in '98the F23 Accord engines had the TDC sensor moved out of the distributor & down to the crankshaft pulley. Maybe Honda made the same change across the board??
WhateverECU you use,it'll want to see both the distributor sensors and the crankshaft sensors (CKF & TDC) that it's expecting.
Old Apr 29, 2008 | 01:31 PM
ORIGINAL: JimBlake
well my ase certified master technician and i are re wiring it, it does have a TDC sensor in it, but i have one by the crank shaft so i am eliminating those wires. going over to the shop around 4 to completely rewire them, and see if she runs, i'll let you guys know how it goes
