DIY CALIPER POLISHING/PAINTING
Old May 30, 2007 | 02:32 AM
jdmjnky's Avatar
Default DIY CALIPER POLISHING/PAINTING
here are some general steps to polishing out your calipers and or painting them using dupli-colors metal cast.
Step 1 remove wheel & asses the situation.
step 2 remove all dirt & grim from any surface to be painted w/ a degreaser of choice. spray solvent Scrub, rinse, scrub, rinse, scrub, rinse, using a mild brush. Then dry. (dry using blow dryer or cloth will do.)
\Name:  inspire001-1.jpg
after a thorough rinse this should be your ending prod.
step 3 polishing here you will need a wire brush & a **** load of elbow grease, unless you are using a drill as i did, w/ a coarse wire brush NOT FINE OR ANYTHING HEAVY! you will damage the caliper by digging into the material. Polish to desired finish
here is a finished sample (if you want it chrome/polished stop here & add a clear coat...high heat/ metalcast clear)
Step 4 mask off areas that you do not want paint on if you are to lazy to remove the caliper as i was. Then begin w/ a light misty coat...proceed with another coat @ a minimum of 10 min. intervals depending on climate.
Old May 30, 2007 | 12:03 PM
sir_nasty's Avatar
Default RE: DIY CALIPER POLISHING/PAINTING
Thanks for posting that! those look great! Can you remove the profanity from your post for us though? Thanks, great post
Old May 30, 2007 | 12:56 PM
03Sleeper's Avatar
Sweet DIY
Old Jun 1, 2007 | 12:13 AM
jdmjnky's Avatar
ORIGINAL: sir_nasty
lol
ORIGINAL: 03Sleeper
Sweet DIY
THANX
Old Oct 20, 2007 | 12:48 PM
dan_o_89_rs's Avatar
ORIGINAL: jdmjnky
awesome diy post.
do youhave a final pic with the wheels on?
i hatemy casting marks... did think of grinding them off for a more smooth look?
RI Jon
Jun 9, 2013 02:48 PM
markus9175
Mar 27, 2009 10:35 PM
Gus64
Nov 14, 2008 02:39 AM
wardykid23
Oct 9, 2007 11:48 AM
KennethPham_725
Oct 27, 2006 12:33 PM
