DIY Request: '94 Accord Rear Upper Control Arm Replacement
Old Sep 13, 2014 | 12:31 PM
cukaracha's Avatar
Default DIY Request: '94 Accord Rear Upper Control Arm Replacement
Hello,
I'm looking to replace the rear upper control arms of my '94 Accord LX soon, and I was hoping for someone to create a tutorial for it? I've watched tutorials on how to replace the front control arms, but I'm not sure how that process will apply to the rear control arms.
Any help at all is greatly appreciated.
Thanks in advance!!
Old Sep 13, 2014 | 05:09 PM
Check the shop manual of the 94 accord. The online manuals thread in the DIY section has a link for it.
The rear arm probably isn't too difficult. You may need to remove the shock/strut assembly to make enough room to remove the upper arm.
Old Sep 13, 2014 | 08:15 PM
cukaracha's Avatar
Thanks for the info! Does it matter if I use the Accord Coupe shop manual with my sedan? I couldn't find any other version of it.
Old Sep 14, 2014 | 09:22 AM
The coupe manual will have almost everything you need for the sedan.
Old Sep 14, 2014 | 04:17 PM
Turtlehead's Avatar
Flange blots torque to 28 ft. lbs. and the castle nut torques 29 to 35 ft. lbs. so that the slots lines up for the new cotter pin.
Old Sep 14, 2014 | 11:09 PM
cukaracha's Avatar
Excellent! Thanks for the info guys!
jkowtko
Dec 20, 2013 05:29 PM
JonJon13926
Jul 8, 2013 11:54 AM
curvenut
Jan 31, 2013 08:36 PM
zero5
Jun 5, 2008 09:39 PM
trukid21
Dec 17, 2006 12:30 PM
