Dodgy Clutch
Old Jul 12, 2011 | 12:10 PM
clive aldridge's Avatar
Unhappy Dodgy Clutch
Hi , need help, getting nagged to death. Had new clutch fitted a year ago, is ok until the engine gets hot then it judders like mad and it is wife's car so you can imagine abuse I get. It is a 99 Accord 2.0 SE . Could it be that a duff clutch was fitted or hyd oil needs change , I don't think it can be adjusted but I would welcome any ideas. Ta.
Old Jul 12, 2011 | 07:52 PM
I know where you are coming from.....anyway, hard to know. Was the flywheel replaced, cut or left alone?...please dont't ask if she rides it, I know where that would get me.
Is there an oil leak (rear main getting on flywheel)?
Are you sure it is in the clutch and not in the engine? If like me I dont get to drive her car that often.
Old Jul 14, 2011 | 03:16 PM
Default Thanks
Flywheel was not replaced or even touched, no apparent oil leaks and she does'nt ride the clutch , I could understand if that was the case. It is a mystery as the clutch is good until we do twenty miles or so then normal use shakes my teeth out.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
Nov 4, 2005 09:54 PM
