Door handle
Old Apr 2, 2011 | 04:36 PM
rah140's Avatar
Default Door handle
I have a 2011 Honda Accord EX, with 6500 miles and I just noticed a problem with the drivers side door handle. When I pull the door handle to open the door, the hinged side of the handle makes a noise and seems to pop out of it's socket slightly. The passenger side does not move at all. Is there a problem with the door handle, since the other side is fine? It may have been there the whole time and I just noticed it. It seems to only happen when you pull on it hard.
Thanks for your help.
Old Apr 2, 2011 | 05:23 PM
Since the car is still under warranty, I would take it back to the dealership to get diagnosed. If it is something that can be easily repeated the dealership should be able to figure it out.
You can try the same thing on a 2011 accord that is on the lot to see if the lock responds the same way.
JPodAccord
May 26, 2012 05:10 PM
Motman Idaho
Mar 22, 2012 10:20 PM
iridebmx33
Sep 23, 2006 01:38 AM
Markus26
May 16, 2006 03:43 AM
ryan ortego
Dec 4, 2005 04:10 PM
