door lock ?
The Online Manuals thread in the DIY section links to site with a 94 shop manual.
Its simple to do, except there is not much space to easily remove the bolts.
You will have to remove the door panel, then lift the lower corner of the plastic protective sheet. Unplug and unbolt the actuator. Installation is the reverse.
Use the new actuator as a reference to see where the bolts are located. I did mine my feeling around back there. A mechanics mirror may help a lot.
pmay805
Mar 16, 2015 10:41 AM
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
