door lock making noise
Old Jul 20, 2007 | 12:35 PM
gtchen66's Avatar
Default door lock making noise
I have a 1996 Accord EX 4-door sedan. After a decade of faithful service, last night the front-passenger side door lock started acting up. Whenever I try to lock the door (either through the remote, the driver side door lock, the outside key, or even just pushing down on the lock) I get a loud squeeching/whirling sound. The door does lock though. Unlocking works just fine. Any ideas what the problem might be? Is this easy/cheap to fix?
On a similar note, I have the original 2 remotes that came when I purchased the car. One of them no longer locks/unlocks the car while the other will work about 70% of the time. I've changed batteries and the light looks bright. Is this something wrong with the remotes or with the car?
Thanks
Old Jul 20, 2007 | 02:08 PM
Chiovnidca's Avatar
Default RE: door lock making noise
Put a door lock actuator on it if it bothers you.
Old Jul 20, 2007 | 02:57 PM
gtchen66's Avatar
Not sure I understand. Is a "door lock actuator" something I add to the car to stop the noise? Or is it a replacement part? Is it easy to install? Thanks.
Old Jul 20, 2007 | 03:26 PM
deserthonda's Avatar
door lock actuator is attached to the door latch assembly, you need to buy it from the dealer,
as for the ease. you need to remove the door panel , with a bit of work , you can replace the actuator without removing the door latch asembly , if you got no clue .. you might either live with the noise or pay a tech to do the job .. should not charge you more that 1-1.5 hr in labor
Old Aug 13, 2007 | 11:41 AM
gtchen66's Avatar
So, it's taken a while to find enough time to do this, but I've finally taken off the door panel and have removed the plastic sheeting. I can see the actuator (off-white) but I don't see how to remove it. The window runner appears to block it's removal. Are there any instructions on how to remove/replace it?
Old Aug 13, 2007 | 10:02 PM
hondadude's Avatar
okay pull the bolt that holds the lower run channel in place, then you'll need a #1 phillips bit to remove the actuator, when the 3 screws are out it will unhook from it's latch connection.
I used to just open up the case and shim the broken spring tab with little washers and epoxy them in place.
Then I got to plastic welding a rod in place to support the tab, 35 watt soldering pencil works great.
Old Aug 15, 2007 | 11:29 AM
gtchen66's Avatar
Thanks. Does it matter what position the window is in? Up/down/halfway?
George
Old Aug 17, 2007 | 12:30 PM
gtchen66's Avatar
Thanks for all the advice. I fixed the problem yesterday. Cost me a tube of superglue and a lot of time. Better than forking over over 500 to the dealer. Here's a photo history of the process:
http://www.flickr.com/photos/6406756...7601502353138/
Old Aug 17, 2007 | 12:38 PM
sir_nasty's Avatar
Awsome write-up on that! 4 hours and $1.99 tube of super glue or $520 and all day.... hmmmm.... which way would I do it?
Thanks for the follow up.
JeffN9
Jul 13, 2015 02:35 PM
pmay805
Mar 16, 2015 10:41 AM
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
bczupryna
Feb 11, 2006 05:50 AM
