Door Lock Squeals
Old Apr 3, 2011 | 06:28 PM
'95 EX SW's Avatar
Default Door Lock Squeals
The rear left door lock on my '95 Accord EX squeals when I lock the car. My guess would be the actuator went bad. Does anyone have knowledge or experience about this?
Thanks,
Dennis
Old Apr 3, 2011 | 07:04 PM
One or both of the rubber stops in the actuator probably broke off. You can repair it. Refer to this thread:
honda-tech.com/showthread.php?t=2465699
Old Apr 4, 2011 | 11:34 AM
Old Honda Dude's Avatar
rear door lock actuators are not an easy deal. I mean you need to be able chew gum and walk at the same time kinda thing.
Old Apr 4, 2011 | 02:53 PM
'95 EX SW's Avatar
Is it possible to just cut the power to this lock, since I do not use the back doors at all?
Thanks
Old Apr 5, 2011 | 05:10 AM
Exclamation possible
All I can say to that is. Yes, it is possible. careful
Old Apr 5, 2011 | 08:40 AM
Removing the actuator to work on is not very difficult. The door panel needs to be remove to access it.
If you simply want to cut power to the actuator, remove the door panel and just unplug the one connector to the actuator.
Go download a service manual from one of the links in this forum.
mclasser
Aug 23, 2015 10:43 AM
pmay805
Mar 16, 2015 10:41 AM
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
bczupryna
Feb 11, 2006 05:50 AM
