Door lock sticking
97 accord four door. The door lock on the rear door behind the driver does not open using the electric locks and will not pull up. After cycling the electric locks many times it may start to work but will always stop working after not being used. The remainder of the locks work. Simple fix? I hope.
Thanks
Thanks
Could be an actuator, or something is somehow just frozen up in there. The only way to find out is to take off the door panel and look at it. Not too complicated once you get the panel off. Clearance is the hard part and getting the panel on & off can be tough.
pmay805
Mar 16, 2015 10:41 AM
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
