drain gas tank youtube method ('92 Accord)
Seems when I follow the line on the left side of my picture it leads to the passenger side of the fuel rail. The line on the right side of my picture seems to lead down and back away from the engine compartment. The line connected to my driver side of the fuel rail connects to the pressure regulator I guess it is, and comes from back down away from the engine compartment. I guess I'm just not clear on what line I'll be needing to disconnect/detach for the procedure, and then how to connect my tubing (which will feed to my gas can) to either the line or the line fitting/connection.
For further clarity to explain my uncertainty and to follow up on my inquiry, the following photos of the fuel rail line connections might help. The first photo is the connection on the driver side: the second on the passenger side. Which do I detach and then where would I try to attach my tubing to my gas can for the procedure? Thanks
The easiest place to disconnect is that hose coming off the fuel pressure regulator in the first picture. Or somewhere downstream towards the gas tank from the first picture.
I think it will be difficult to find a way to connect to the eyelet in the 2nd picture without getting fuel everywhere.
Thanks, so I went ahead and disconnected that hose coming off the fuel pressure regulator and connected my own tube to its nipple and running down to my gas tank. With the relay jumped and with the key turned to the on position gas did indeed flow steadily out through my tube to the can. But, very slowly, just sort of a weak slow trickle instead of flowing full and strongly. Unless I could do something different or additional it would take a very long long time to finally drain my 3/4 tank of gas this way, plus probably the battery would discharge all the way beforehand. Any suggestions on why such a slow trickle and what I might do to increase and speed up the flow?
Actually it turns out even though the flow isn't as fast as I'd like, I found if I stay patient and just let it pump out at the rate it steadily pumps out, it doesn't take all that long to fill up a 5 gal gas can a few times. It works pretty good. Kinda fun sitting there watching the gas gauge needle on the dash go down while the gas pumps out into my can(s). But not so much fun I'd want to do it very often. Thanks again for replies.
Sad to see the 4th gen going to the big grave yard in the sky......can I ask what did it in?
Was always a pleasure help you in the past......hope thing as going well for you and the family.....poorman.
Poorman it was indeed a pleasure to have you help me in the past on the ol' 4th gen. Other than this mechanical misfortune or whatever we could call it (and I've already had sufficient grieving time) things are going well for me and the family and I hope the same for you.
Neptun3
May 20, 2013 04:42 PM
jon02accord
Mar 26, 2008 10:54 AM
