Draining coolant
Old Jan 29, 2012 | 10:45 AM
nsx's Avatar
nsx
Default Draining coolant
I have searched, but can't find this info. I'm changing the coolant in my '06 Accord Hybrid, and found nothing in the owner's manual about drains, vent screws, etc. I found the drain on the bottom of the radiator (is there more than one?), but is there a bleed screw or screws for bleeding air from the system, and if so, where?
Thanks for any info. This forum is great.
Old Jan 29, 2012 | 11:04 AM
I've always just drained the radiator. This leaves a quart or 2 of old coolant behind. The drain plugs are very difficult to access. I'm not sure where there are on V6.
Old Jan 29, 2012 | 11:12 AM
For just draining and filling, use the one on the rad.....I'm pretty sure there is one the block as well but that is over kill in my opinion.
Me, when you are draining if you have auto HVAC, turn the heat to max, you will have to start the car so the hvac motor opens the heater valve.
For the re-fill, no there is not a "bleeder". There is a series of starting, hold rpm's at a range for this amount of time, shut it off-check/top off with a few repeats.
EDIT-too slow at typing....TX answered as well
Old Jan 29, 2012 | 11:49 AM
nsx's Avatar
nsx
Thanks to both of you, just what I needed to know. I had forgotten about the heater valve.
theduffmeister
Dec 9, 2010 05:05 PM
RTM1216
Apr 12, 2009 12:54 PM
driver6198
Jan 2, 2009 11:19 PM
BallaxB09
Dec 12, 2007 06:21 PM
