Drive Belt Noise - How Do I Know Which One?
Old Jun 13, 2014 | 10:37 AM
19962door's Avatar
Default Drive Belt Noise - How Do I Know Which One?
I just returned from a short drive in a heavy rain.
When I parked the car, I could hear a drive belt noise. I turned of the engine for a few minutes, and when I turned it back on again, the noise was still there.
The belts are definitely tight, and no fraying was observed. I'm not sure if these are the original belts, but I can find out if needed. The A/C wasn't on at any time.
Rob
Old Jun 13, 2014 | 04:44 PM
By drive belt noise, do you mean squealing/slip noise?
If yes, your belts may be a bit loose. Easier to adjust both belts than try to determine which is causing the squeal. Most adjust belts so longest span will deflect 1/2" under firm (25-40 lbs? no spec here). This ia usually adequate.
If belt/s slip after adjustment, you may have a severely worn belt that is polished or glazed increasing slip tendency. Suggest replacing both belts.
Old Jun 13, 2014 | 08:29 PM
woody31's Avatar
Almost A Senior Member
you can try taking off one belt and start the engine for just a moment, if it goes away thats the belt,,if not it is the other one,,DO NOT use any type of belt dressing , ask me how i know. lol, good luck and keep us posted of your findings.
Old Jun 14, 2014 | 11:00 AM
19962door's Avatar
Thanks - I'll keep everybody posted on this.
BTW, how do you know about belt dressing being a no-no? Did u use a dressing and have the belt slip off?
Old Jun 14, 2014 | 07:10 PM
I've used belt dressing but you have to remember it's not a permanent fix. I've suggested it as a diagnostic device - if it makes the squeal go away then it's a bad belt.
Belt dressing might increase the grip of a belt that's getting old & slippery. It doesn't last a real long time, but might get you home. But at the same time if you over-tighten the belt then you start having trouble with alternator bearings & stuff like that.
Belts get hard & slippery with age, sometimes that happens without any fraying. No real fix except a new belt.
Old Jun 16, 2014 | 09:23 AM
19962door's Avatar
Hi Jim:
I took the car out yesterday for local and highway driving. I didn't hear any noise, either at idle or speed.
Now that I've read your post discussing over-tightened belts, I'm leaning towards leaving everything alone. I checked the belts, and I don't detect any fraying, nor do the belts feel hard.
What is the best approach here?
Question re posting - I have to edit each post, as the preview has two lines skipped between each paragraph. Is there a setting I need to change to get a single line between paragraphs?
Thanks,
Rob
Old Jun 17, 2014 | 08:46 PM
kris_loehr's Avatar
If the noise returns take a bar of soap and push it into the belt when running. If the noise goes away you found the bad belt.
rameel4
Nov 3, 2011 10:31 PM
pmatos
Apr 12, 2009 01:04 AM
ksar
Oct 17, 2008 09:27 AM
Jeff247
Dec 29, 2006 07:15 PM
thunder_x
Sep 19, 2006 01:01 AM
