driver seat
Old Sep 28, 2006 | 08:32 PM
evs's Avatar
evs
Default driver seat
I have a question about the driver seat, mine is an electric one and it has a little play back and forth. Is this normal or should i tighten something, if i should what ?
Old Sep 29, 2006 | 07:00 PM
sir_nasty's Avatar
Default RE: driver seat
it's probably normal but just to be safe check and make sure all your mounting bolts are tight.... there should be 2 in front and 2 in the back that mount the seat to the car.... give it a shot and let us know what you find...
Old Sep 29, 2006 | 11:11 PM
evs's Avatar
evs
Ok, ill give it a try tomorrow
Old Sep 30, 2006 | 09:11 AM
Chiovnidca's Avatar
ORIGINAL: evs
Year and model?
Old Sep 30, 2006 | 07:42 PM
evs's Avatar
evs
99, accord coupe...
The mounting bolts are tight.. the part that i can see moving is the whole seat but from the buttons to move the seat, upward, whats below that does not move.
Old Sep 30, 2006 | 07:57 PM
sir_nasty's Avatar
If it's not loose bolts under the seat or somewhere then I'm not sure what you can do....
Old Sep 30, 2006 | 08:03 PM
evs's Avatar
evs
the only reasonable thing i can think of is that the motor has a little play...
Old Sep 30, 2006 | 08:37 PM
Chiovnidca's Avatar
ORIGINAL: evs
Possibly a problem covered by service bulletin #03-034: Product Update: 1998–01 Accord 8-Way Power Driver’s Seat
A dealership can run your vin to see if your vehicle is affected. (or you can pm me the vin and i'll check it)
jza240sx
Apr 30, 2013 04:14 PM
JOE.G
Nov 4, 2012 08:48 AM
Johnny Racer
Sep 13, 2012 07:43 PM
MysticBlueEX
Feb 18, 2011 06:55 AM
lacrw
Aug 1, 2007 08:43 AM
