driver side AC not working
Old May 8, 2009 | 02:45 PM
manu_b's Avatar
Default driver side AC not working
drivre side ac is not working i checked with the self diagnostic but it showed no codes. i pulled out the driver side air mix motor to see if it was working. i was working ok. i have no idea whats wrong with it. if i have to see if there is problem with air mix door how do i open it. or is it something else
________
ZOLOFT LAWSUIT SETTLEMENTS
Old May 8, 2009 | 06:25 PM
I have heard of this symptom before, but never experienced myself. The problem occurs when the AC charge is low. The evaporator is only partially cooled and some air passes through the warmer portion of evap, resulting in problem you've experienced. You need to get a set of manifold gauges to check hi side and low side pressures. You should see low side slightly low (perhaps 15-25 psi) and high side more significantly low (perhaps 1.5-2 x ambient air temp in degF). Check w/ engine at 1500 rpm, doors and windows open, recirculate. This should cause the compressor to stay engaged full time. If it's cycling on/off, this is further indication of low charge.
Or you could pay a shop to remove charge, and refill to specification charge.
Note, you likely have a small leak somewhere that led to partial loss of charge, however a recharge might last a year or more.
Old May 8, 2009 | 09:03 PM
manu_b's Avatar
thanx for quick reply. i`ll get it recharged
________
HAWAII MEDICAL MARIJUANA
Old Aug 17, 2009 | 07:17 PM
emsman1
Did you get it charged? Did that resolve the issue?
bvkiran
Mar 3, 2010 10:23 AM
Antarctica
Jan 31, 2009 03:25 AM
stevelaker
Jan 15, 2008 05:38 PM
Buktheng
Dec 6, 2007 05:49 PM
