Driver side radiator fan does not work
Old Mar 20, 2011 | 06:25 PM
mjquillici's Avatar
Default Driver side radiator fan does not work
And I don't know why! When I turn on the A/C, only the passenger side fan turns on. Could the fan motor be dead??
Old Mar 20, 2011 | 06:55 PM
It could be a bad motor, no power/ground.
Unplug the electrical connector for that fan and turn on the a/c. Use a volt meter to see if there is 12V across the two pins. If you have 12V, then you fan motor is bad.
No voltage, then something is wrong upstream (fuse, relay, etc..) and you will have some more tests to do.
Old Mar 20, 2011 | 08:28 PM
mjquillici's Avatar
OK. I did exactly that, and I have 14.1 volts across the pins whenever the A/C compressor is running. No problem.
However, I made the mistake of unplugging the connector while the one fan was running. After plugging the connector back in, now neither fan works. Could I have zapped something when I unplugged the connector? I still have 14.1 volts across the pins, so the fans are definitely getting the signal to run. . .
Old Mar 20, 2011 | 09:07 PM
mjquillici's Avatar
UPDATE: It's definitely the fan motor. I tapped it with a hammer, and it feebly began to spin before it quite again. I also tapped the passenger side motor, and it started right back up again at full speed. . .phew!
Old Mar 20, 2011 | 09:28 PM
Sounds like your passenger side motor might be next to fail?
Old Mar 20, 2011 | 09:49 PM
mjquillici's Avatar
Yeah. I'm thinking that too. On the bright side, it looks like they sell just the motor at the auto parts store, so at least I don't need to buy the entire assembly.
Old Mar 21, 2011 | 10:59 PM
mjquillici's Avatar
New fan motor installed. We're rolling again!
Novaknowledgenow
May 30, 2013 08:58 PM
CDJDM07
Aug 24, 2011 09:51 AM
accordgary07
Apr 10, 2011 07:47 AM
ksorbo
May 24, 2007 11:20 PM
