Drivers window ,, help
Old Sep 20, 2014 | 07:23 PM
woody31's Avatar
Almost A Senior Member
Question Drivers window ,, help
On my 96 accord 4 door, the drivers window rocks back in forth in the channel, when you roll it up u have to hold the window in the slot or it will push out at the top,, any ideas?? is it a easy fix ?? thanks
Old Sep 20, 2014 | 08:31 PM
You probably need to remove the door panel and adjust the glass.
Open the online manuals thread in this link: https://www.hondaaccordforum.com/for...threads-40780/
The 94 accord shop manual will show the procedure.
Here is a video on replacing the run channel.
Watch How To Replace A Window Run Channel ( 97 Honda Accord) | EricTheCarGuy Episodes | How To Videos | Blip
You can see how to remove the door panel. You may want to clean and lubricate that run channel too.
Old Sep 20, 2014 | 08:32 PM
There is also a link in that common diy thread for glass jumping the track that you should check out.
Let us know how this turns out.
Good luck.
Good luck.
Old Sep 21, 2014 | 08:03 AM
woody31's Avatar
Thank you for your time and replies, What type of lube do I use in the run channel?
Old Sep 21, 2014 | 08:17 AM
Well the "good stuff" costs a bit - ~$20 Shin-Etsu Grease.
Other than that you can use some other type of lube, I've use white lithium before with some luck.
Old Sep 21, 2014 | 03:30 PM
woody31's Avatar
i looked and do not see a link or anything related,,can someone post a link to the proper repair or diagnosis, thanks
Old Sep 21, 2014 | 04:46 PM
The link is part of this thread. I posted the instructions from a Honda Service News article there previously. You would reposition the window regulator and front channel.
It is under "94-97 Door glass jumps track".
Old Sep 21, 2014 | 07:47 PM
woody31's Avatar
thanks,,it seems difficult,,can this be done at home or does it need to go to the shop,,
Old Sep 21, 2014 | 07:56 PM
It is not very difficult and can be done at home.
Michael Bomes
Sep 9, 2012 03:12 PM
Major
Jun 2, 2007 06:10 AM
Crabby
Jun 1, 2007 09:11 AM
adamc44
Feb 11, 2007 03:02 PM
lostinspace
May 31, 2006 10:17 PM
