Drum brakes
Old Aug 14, 2013 | 12:53 AM
kuckle's Avatar
Default Drum brakes
Ok so my right rear drum brake was leaking brake fluid so I decided to check it out, and after taking everything off the rubber boots on the solenoid have punctures in then and continuously leaks brake fluid, so I guess my question is, can I get this at autozone or something and is it pricey?
Old Aug 14, 2013 | 01:01 AM
Hi New Member..You need to put in the year, make , model of your ride to get correct help. I am AutoZone EX and I'm going to say yes to your ??? and no it won't cost you much..
WheelBrokerAng..
Old Aug 14, 2013 | 01:21 AM
kuckle's Avatar
Oops sorry about that, it's a 1994 Honda accord MT, thanks by the way and what's the name of the part?
Old Aug 14, 2013 | 01:48 AM
Sounds like you're describing the wheel cylinders are leaking. They are available at Autozone or other parts places for not too expensive.
If you don't have it the service manual, it is available for download in the "Common DIY and Info Thread" sticky above.
Old Aug 14, 2013 | 01:51 AM
kuckle's Avatar
Thanks much appreciated!
Old Aug 14, 2013 | 02:40 AM
You got it and Thank You for posting..
Old Aug 14, 2013 | 11:34 AM
Get wheel cylinders. The rubber boots are just dust-boots. If there's fluid leaking out, then you need more than just the dust boots.
status
Jan 24, 2009 08:01 PM
01AccordOwnr
Aug 8, 2007 10:17 AM
01AccordOwnr
Aug 7, 2007 08:39 PM
Bearcat
Apr 21, 2007 07:45 AM
thunder_x
Sep 27, 2006 11:00 PM
