ecu
can any body tell me wich ecu i need for honda accord 1996 with jdm f23A as im runing the engine now on the existing p08-A20 but no vtec. i end up with 2 ecu non is working plugs are different.thanks
Can you explain the part I quoted above, because I don't understand what you mean?
Also, can you tell us more about the swap? Like what accord the engine came from, what wire harness you used, etc...
its honda accord 1996 ex with h22b 24 valve .i did change the engine to f23a sohc vtec im using same harness same distributer and same manifold same ecu pob A20 from old motor,everything works fine exept the vtec witch im looking for the proper ecu to run the engine and the vte.c thanks. for u quick email
live2rice
Sep 20, 2012 02:26 PM
