efan wont shut off
Old Aug 14, 2006 | 01:20 PM
pixelmonkey
Default efan wont shut off
1991 LX
the radiator fan *passengers side* wont shut off. If i disconnect the battery, wait for the fan to stop and then reconnect the battery it will stay off, otherwise it keeps running.
anyone know where the thermostat relay is located? i'm thinking this is the problem part.
thanks
chris<pixelmonkey>
Old Sep 2, 2006 | 08:03 PM
hondadude's Avatar
Default RE: efan wont shut off
The most common cause of that problem is the temp sensor that is inline of the top radiator hose, to prove it unplug the sensor when the fan is running. If the fan stops the sensor is bad.
If this doesn't help you the fan timer unit will need to be checked, repost for more help.
Old Sep 3, 2006 | 04:18 AM
Sounds like the fan timer module is bad too. The job of the timer module is to shut off the fan EVEN IF THAT FAN SWITCH is stuck closed.
tseigh
Jul 7, 2011 02:14 PM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
thedaveman89
Jan 10, 2009 03:06 AM
accordinglyslow
May 8, 2007 10:24 PM
live2rice
Apr 18, 2007 09:27 PM
