EGR vs EVAP Repair
Old Nov 30, 2014 | 11:25 AM
sheelthemagnificent's Avatar
Default EGR vs EVAP Repair
Hi guys. My daughter has a 2000 Accord V6 with about 205K miles. Last week the car developed starting problems. Cold starts were ok but restarts after 20 min. or more of driving were a big problem, taking many restarts before engine would keep running. The check engine lite went on. Honda dealer said the problem was due to EGR ports being clogged with carbon, and EGR valve not working. She had ports cleaned and new valve installed, for $585, and car is good now. Looking back through repair history for her car I found a repair done in 7/13 when check engine light came on. Code pulled was P1457. Charcoal canister and vent valve were replaced (mileage 195K). Is this the same repair as the one described above (EGR) or is it different? Just checking for my own education. I will get the code pulled for the EGR repair.Thanks.
Old Nov 30, 2014 | 11:38 AM
EGR port clogged generally will give a P0401.
P1457 is leak detected in EVAP control system (EVAP control canister system). Although it may be something else on the canister side of the EVAP system, some of the usual culprits are the EVAP bypass solenoid valve or the EVAP vent shut valve.
Old Nov 30, 2014 | 12:19 PM
I moved your posts and made a new thread, so the original one isn't confusing with two different problems.
The EVAP system is different from the EGR system, so this wasn't the same repair.
Old Dec 7, 2014 | 09:07 PM
fourcam's Avatar
evap is evaporative emissions containment, it doesnt let unburnt exhaust gases into the atmosphere.
egr is exhaust gas recirculation. it is also emissions control, it introduces inert exhaust gases into the combustion chamber to reduce combustion temps, reducing NOx emissions.
unrelated as aforementioned
NordAccord2000
Jan 29, 2013 12:30 AM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
Brian R
Jun 22, 2009 07:59 PM
RJLhonda
Sep 9, 2008 01:05 AM
bww
Sep 23, 2007 10:24 AM
