electrical
Old Mar 21, 2008 | 01:29 PM
eltib3
Default electrical
battery light on,draining battery. altanater is good and coil.
Old Mar 21, 2008 | 01:45 PM
eltib3
Default RE: electrical
1990 LX Battery light is on draining battery. Already have checked altanator and coil! help
Old Mar 21, 2008 | 02:53 PM
Welcome!
The new-member area is mostly for saying HI to each other.
I'm gonna move this to the 'general tech' area so more people are likely to notice it & respond.
The coil should not be related to your problem.
Exactly how did you check the alternator? It really sounds like your alternator is NOT OK.
Old Mar 21, 2008 | 03:48 PM
eltib3
Had 24 amps coming off main lead on altanater and 12 volts off of 4prong connecter when car running. I think it may be a short some were. When I disconect 4 prong connecterbattery light goes off.
Old Mar 21, 2008 | 03:51 PM
eltib3
Had altanater checked out at napa and chucks and they siad it was good
Old Mar 23, 2008 | 09:36 PM
Won't it charge up to 13.5 or so when it's running?
Start pulling fuses until the 24 amp load goes down. See if it'll charge up then.
Mydnght2u
Jan 17, 2006 07:18 PM
LaminatedKitten
Dec 23, 2005 02:09 AM
zelseman
Dec 11, 2005 11:44 AM
cloob
Oct 25, 2005 09:55 PM
bear67
May 29, 2005 04:10 PM
