Electrical issues
Old Mar 13, 2014 | 03:33 PM
Banky's Avatar
Default Electrical issues
My 2006 EX Accords engine check and airbag lights wont come on, however I took the cluster apart and used my tester and the diodes light up but they wont work when I switch the ignition or vehicle on. I dont have an OBD scan tool and I need some help please. Thanks. S
Old Mar 13, 2014 | 10:56 PM
Can you give us more details on how you know the bulbs are not working? Did you do any work on your car before you noticed these symptoms?
Old Mar 15, 2014 | 01:47 PM
Banky's Avatar
Thanks for your reply. The bulbs are working. I just grounded the tester and checked them and they lit up. Turns out someone opened the cluster and put electrical tape on the inside so the engine check light and seatbelt light would not show. I biught the car from a dealer in South Carolina and I knew it was in a accident but was willing to do the work on it to get the little issues straighten out. So now I'm getting codes from the SRS light and engine check light., SRS 4-1, 3-3, & 31 turns iut I need to repair or replace the seatbelts
accordstuff
Sep 22, 2007 07:42 PM
96V6accord
Aug 25, 2007 11:42 PM
leg_of_tape
Feb 10, 2007 07:42 PM
misterpoop
Nov 30, 2006 11:20 AM
honsolo
May 19, 2006 03:18 PM
