Electrical Problems?
Old Aug 5, 2010 | 10:56 AM
E.Honda93's Avatar
Default Electrical Problems?
Ok today as soon as I get to work I notice that ALL of the taillights were ON, I didn't have the time to try and figure this out so I disconnected the battery so it wouldn't drain it.
1. Has anyone had this problem?
2. Is there a fast solution for this?
3. What does any of you think it is?
Old Aug 5, 2010 | 01:05 PM
Next time it happens, try lifting up on the brake pedal.
Bad brake-pedal switch turning ON the brake lamps.
Missing little rubber plug on the brake pedal - that plug is supposed to press the pin of the brake switch when the pedal is UP.
Old Aug 5, 2010 | 03:33 PM
E.Honda93's Avatar
Jim they still are on its just I disconnected the battery.
As to the part ur talking idk. I have take a look at it.
Thanks for taking ur time and responding.
Old Aug 5, 2010 | 04:41 PM
Look up near the hinge of the brake pedal. Should be a switch with a button sticking out. When you press down the brake pedal, it should allow that button to spring out, turning on the brake lamps.
When you let the brake pedal UP, it should push in that button which turns OFF the brake lights.
Just look to see if that's working correctly. It's not uncommon for the switch to be broken. Also the little rubber bumper that presses the switch can dissappear. It's pretty cheap at the dealer.
Old Aug 5, 2010 | 05:35 PM
deserthonda's Avatar
TAIL or BRAKE lites??? 2 different issues 2 different fixes ,, since you did not mention anything about the frt parking lites staying also on , i would have to assume that it is the brake lites as well
if it is brake lites follow Jim's suggestions
if it is tail lites there is another issue..
Old Aug 6, 2010 | 09:42 AM
Originally Posted by robinmarkk
I think it is a normal problem. It is a problem of your car battery. .
No offense,, but what are you smoking ??? IT IS NOT a normal problem at all and it is not the car battery causing the lites to stay on ,,,,,,,,
Old Aug 7, 2010 | 09:45 AM
E.Honda93's Avatar
Default Update
Good call, Well today I got off work early and had time take a look at it, sure enough it was the brake pedal switch torn into little pices on the floormat so I just put 2 layers of doble side tape and problem fixed I ofcourse did not removed paper covering on side of the switch so it wouldn't stick to the switch. Something so simple had me thinking for about 2 or 3 days. Thanks alot Jim.
Old Aug 7, 2010 | 10:43 AM
Go to the dealer, as soon as you can, and get the proper plug (~ $3). You can lookup the part number online (google for majestic honda). The tape will hold for a while but not forever. The OE plugs last @ 20 years or so....
ky10ww
Sep 28, 2007 01:19 PM
seldon
Jun 27, 2007 05:45 AM
ronny_west
Feb 3, 2007 05:28 AM
thomas rouw
Oct 21, 2006 02:09 AM
KimberlyC
Apr 16, 2006 11:51 AM
