Engine control management system
Old Jun 13, 2014 | 03:04 PM
exaramco's Avatar
Default Engine control management system
Is there some kind of indication on the instrument panel when the engine management system shuts off three cylinders?
Thanks.
Old Jun 13, 2014 | 03:13 PM
What year and model do you have?
Old Jun 13, 2014 | 03:49 PM
exaramco's Avatar
I have a 2014 Honda Accord 6 cylinder.
Old Jun 13, 2014 | 04:42 PM
There is no direct indicator on the instrument panel of whether Variable Cylinder Management (VCM) is active between switching from 6, 4, or 3 cylinder combustion.
The ECON mode indicator on the instrument panel comes on when the ECON button is pressed. The ‘ECON’ button optimizes operation of the transmission, engine, and other powertrain components to help conserve additional fuel. For example, a gentler throttle pedal setting limits power and torque by a small amount. Also, air conditioning is set to consume less energy by operating more in the recirculation mode or reducing the speed of the automatic climate control blower.
VCM could be active and the ECON mode indicator light doesn't have to be lite, and vice versa.
Old Jun 13, 2014 | 05:12 PM
exaramco's Avatar
Thank you for the information. I wish there was a way of turning off VCM.
christenajenifer
Apr 21, 2010 09:48 AM
boarderdog05
Nov 12, 2008 03:52 PM
kris.h1987
15
Apr 29, 2008 02:41 PM
wapunga
May 1, 2007 01:34 PM
